Some of my customers have reported problems when shopping online at certain sites.. I’ve verified it at several locations using dsl, cable and t1’s..
One of the sites is http://www.1800diapers.com.. If you click on Diapers on the top right below Home and then on the next page pick a size, quantity, then click add to cart and it just sits for a couple minutes and eventually firefox will say Connection Reset. it also does the same thing when you try to click checkout..
I’ve tried on multiple computers using different browsers. I’ve also tried taking a brand new rb532 and doing a very minimal setup on a dsl line from a diff provider and it does the same thing.
If I put a linksys router in place of the mikrotik it works just fine.
It does the same thing if the mikrotik is routing public ip’s to the customer or natting privates.
Here is my minimal dsl config..
http://shelbywireless.com/1800diapers.txt
Does 1800diapers.com work for you when using mikrotik?
Any ideas?
thanks
-Gerard
