When selecting products to reduce hyper pigmentation, make sure you consult a dermatologist beforehand as products for skin care for men with dark skin differ from those of men with lighter skin when it comes to removing marks, scars, melasma and abnormal pigmentation. Choosing the wrong product will either make the marks lighter than the surrounding skin tone or will not treat the pigmentation issue effectively enough. Avoid alcohol-based toiletries and cosmetic products completely as they can cause the area of Retinolla application to darken permanently. Cut out on caffeine and alcohol to avoid getting ugly, puffy bags under your eyes. Get a body massage and a mild, preferably herbal facial treatment at least once every month to feel rejuvenated and relaxed. Give your body sufficient amounts of rest and do not push yourself to perform rigorous workouts that are too taxing on your body. The idea is to keep your body running and maintained, not to punish it.
feel ashamed and embarrassed cause Dull and wrinkly skin? Find Solution Here ====>>>> http://www.dermayouth.org/retinolla
