HTTPS does not work
I cannot access any secure https sites such as: Yahoo Mail
It opens up and the following address shows in the address bar and it just hangs.
https://login.yahoo.com/config/login_verify2?.intl=us&.src=ym
Here are the details that fewi requests.
[admin@UBNTMik] >  /ip address print detail
 0   address=10.0.0.48/24 network=10.0.0.0 broadcast=10.0.0.255
     interface=ether1 actual-interface=ether1
 1   address=192.168.2.1/32 network=192.168.2.1 broadcast=192.168.2.1
     interface=Night actual-interface=Night
 2   address=192.168.3.1/32 network=192.168.3.1 broadcast=192.168.3.1
     interface=Day actual-interface=Day
 3 X address=192.168.7.10/24 network=192.168.7.0 broadcast=192.168.7.255
 4   address=10.0.11.49/24 network=10.0.11.0 broadcast=10.0.11.255
     interface=ether3 actual-interface=ether3
 5   address=10.0.12.1/24 network=10.0.12.0 broadcast=10.0.12.255
 6 X address=10.0.0.29/24 network=10.0.0.0 broadcast=10.0.0.255
     interface=ether2 actual-interface=ether2
16 D address=10.5.60.14/32 network=192.168.17.248 broadcast=0.0.0.0
     interface=<pppoe-zak@test> actual-interface=<pppoe-zak@test>
[admin@UBNTMik] >
[admin@UBNTMik] > /ip route print detail /ip route print detail
 0 A S  ;;; 2 WAN route
        dst-address=0.0.0.0/0 gateway=10.0.12.27,10.0.11.22
        gateway-status=10.0.12.27 reachable ether1,10.0.11.22 reachable ether3
        check-gateway=ping distance=1 scope=30 target-scope=10
 1 ADC  dst-address=10.0.0.0/24 pref-src=10.0.0.48 gateway=ether1
        gateway-status=ether1 reachable distance=0 scope=10
 2 ADC  dst-address=10.0.11.0/24 pref-src=10.0.11.49 gateway=ether3
        gateway-status=ether3 reachable distance=0 scope=10
 3 ADC  dst-address=10.0.12.0/24 pref-src=10.0.12.1 gateway=ether1
 4 ADC  dst-address=192.168.2.1/32 pref-src=192.168.2.1 gateway=Night
        gateway-status=Night reachable distance=0 scope=10
 5 ADC  dst-address=192.168.3.1/32 pref-src=192.168.3.1 gateway=Day
        gateway-status=Day reachable distance=0 scope=10
 6 ADC  dst-address=192.168.17.243/32 pref-src=10.5.60.14
        gateway=<pppoe-zak@test> gateway-status=<pppoe-zak@test> reachable
        distance=0 scope=10
[admin@UBNTMik] > /interface print detail
 0  R  name="ether1" type="ether" mtu=1500 l2mtu=1526
 1  R  name="ether2" type="ether" mtu=1500 l2mtu=1522
 2  R  name="ether3" type="ether" mtu=1500 l2mtu=1522
 3  R  ;;; Day PPPOE Radius
       name="Day" type="bridge" mtu=1500 l2mtu=65535
 4  R  ;;; Night PPPOE Radius
       name="Night" type="bridge" mtu=1500 l2mtu=65535
14 DR  name="<pppoe-zak@test>" type="pppoe-in" mtu=1480
[admin@UBNTMik] > /ip firewall export
# nov/07/2011 19:23:32 by RouterOS 4.17
# software id = 6S61-VQPK
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall mangle
add action=mark-packet chain=prerouting comment=\
    "Unthrottle all local downloads and uploads" disabled=no dst-address=\
    10.0.0.0/24 new-packet-mark=up passthrough=yes
add action=mark-packet chain=postrouting comment=\
    "Unthrottle all local downloads and uploads" disabled=no new-packet-mark=\
    down passthrough=yes src-address=10.0.0.0/24
add action=masquerade chain=srcnat comment="" disabled=no out-interface=\
    ether1
    ether3
add action=redirect chain=dstnat comment="" disabled=no dst-port=80 protocol=\
    tcp to-ports=3129
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
[admin@UBNTMik] >
It looks like port 80 gets natted and goes through a web proxy, but you forgot about 443 and it doesn’t get natted.
i forgot to mention that not ALL https does not work. there are 3 that i know dose not work,
  1. gumtree.co.za (cannot sign in to : https://secure.gumtree.co.za/capetown-westerncape/s-SignIn?rup=DefaultPage&ruq=redirect%3Dwww )
  2. yahoo mail
  3. paypal
and GMAIL works
https://mail.google.com works and i can login with no problems
