Hi Friends,
My problem is about a web app We made for full control of our WISP, so I’ve problems with access the api with the https site.
It’s all ok about HTTP but no HTTPS, there is any advice with this?
Thanks!
Hi Friends,
Thanks!
https access relies on many things. check what version of TLS you are using to access it.
Normal, TLS 1.2
I must set the cert in the mikrotik?
Or just try to access with any special config in my PHP Class?
