https webpage timeout
Hello everybody, is my first time on this forum, i was looking for some articles about https into browser webpage timeout
There is some https webpage that say timeout and i dont know why
bevore i have a fritz box 7530 and work all, after i put a Hap AC to get more experience in mikrotik (i already use but i want learn more), from when i put my hap ac i start having problem with some https website (not every https) in my case are verti.it, speedtest.net, test.eolo.it.
the test i’ve made:
i try to disable some or all firewall rules and nat but nothing
try to reset and reconf the router, nothing
i started to reset and put a very poor configuration, adding a piece very day, it look working, at the end i have the same configuration as when i got problems, but this time without problems…
now i put an HAP ac3, export the old conf from AC and put into AC3, vpn, firewall, nat, work everything but i have again problem with these https page (with eth or wifi, but if i use openvpn on my phone i can open)
is not a problem from ISP or DNS (i have my own pi-hole dns and it work since i have 7530, but i already tried with google dns without resolve)
anybody have same experience? im getting very confused about it and i dont find what could be
Ciao, meglio se metti un /export sul forum, sostituendo i dati sensibili con *** (non cancellare niente) così do’ un’occhiata,
come potrebbero farlo altri membri quando vedono l’export.
Quando chiedi aiuto ricordati sempre di specificare la versione di RouterOS e il modello preciso del dispositivo (nell’export ci sono entrambi)
IU5
CONFIGURATION
i export the conf and remove some private with ***
the conf just have a IP wan (not ppoe), some firewall rules for vpn, some nat (most of them disable), wifi, dhcp, l2tp openvpn
# sep/23/2022 12:51:44 by RouterOS 7.5
# model = RBD53iG-5HacD2HnD
add arp=proxy-arp name=LAN
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=PC
set [ find default-name=ether3 ] comment=SWITCH
set [ find default-name=ether4 ] comment=NAS
/interface eoip
add allow-fast-path=no mac-address=02:57:90:89:8B:B6 name=eoip-tunnel1 \
    remote-address=192.168.10.5 tunnel-id=2929
/interface lte apn
add authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys \
    name=profile1 supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-eC \
    comment=2.4 disabled=no frequency=2457 installation=indoor mode=ap-bridge \
    security-profile=profile1 ssid=DAVID-2G
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-eeCe \
    comment=5 disabled=no frequency=5220 mode=ap-bridge security-profile=\
    profile1 ssid=DAVID-5G
/interface wireless manual-tx-power-table
set wlan1 comment=2.4
set wlan2 comment=5
/interface wireless nstreme
set wlan2 comment=5
add name=dhcp_pool1 ranges=192.168.10.100-192.168.10.150
add name=pool-vpn ranges=192.168.10.6-192.168.10.10
add address-pool=dhcp_pool1 interface=LAN lease-time=1d name=dhcp1
/ppp profile
add bridge=LAN local-address=192.168.10.254 name=l2tp only-one=yes \
add bridge=LAN local-address=192.168.10.254 name=l2tp2 only-one=no \
    remote-address=pool-vpn
add local-address=192.168.10.254 name=ovpn remote-address=pool-vpn
add bridge=LAN ingress-filtering=no interface=ether3
add bridge=LAN ingress-filtering=no interface=ether4
add bridge=LAN ingress-filtering=no interface=wlan1
add bridge=LAN ingress-filtering=no interface=ether2
add bridge=LAN ingress-filtering=no interface=wlan2
add bridge=LAN ingress-filtering=no interface=eoip-tunnel1
add bridge=LAN ingress-filtering=no interface=ether5
/ipv6 settings
/interface l2tp-server server
set authentication=mschap1,mschap2 default-profile=default enabled=yes \
    use-ipsec=yes
/interface ovpn-server server
set auth=sha1 certificate=SERVER cipher=aes256 enabled=yes port=1094 \
    require-client-certificate=yes
add address=192.168.10.254/24 interface=LAN network=192.168.10.0
add address=192.168.2.253/24 interface=ether1 network=192.168.2.0
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.254 \
    netmask=24
set servers=192.168.10.1
add action=accept chain=input src-address=192.168.10.0/24
add action=accept chain=input src-address=192.168.2.0/24
add action=accept chain=input comment=ovpn port=1094 protocol=tcp
add action=accept chain=input comment="x vnp l2tp" port=1701,500,4500 \
    protocol=udp
add action=accept chain=input comment="vpn l2tp" protocol=ipsec-esp
add action=accept chain=input comment="eoip tunnel" protocol=gre
add action=drop chain=input connection-state=new src-address=0.0.0.0/0
/ip firewall mangle
add action=change-mss chain=forward disabled=yes new-mss=1300 out-interface=\
    ether1 passthrough=yes protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat src-address=192.168.10.0/24
add action=dst-nat chain=dstnat comment=pc-win4icom disabled=yes dst-address=\
    192.168.2.253 dst-port=5001 protocol=tcp to-addresses=192.168.10.99 \
    to-ports=5001
    192.168.2.253 dst-port=5001 protocol=udp to-addresses=192.168.10.99 \
    to-ports=5001
add action=dst-nat chain=dstnat comment=telefono disabled=yes dst-address=\
    192.168.2.253 dst-port=5060 protocol=udp to-addresses=192.168.10.115 \
    to-ports=5060
    192.168.2.253 dst-port=50002 protocol=tcp to-addresses=192.168.10.99 \
    to-ports=50002
    192.168.2.253 dst-port=50002 protocol=udp to-addresses=192.168.10.99 \
    to-ports=50002
add action=dst-nat chain=dstnat comment=server-FTP dst-address=192.168.2.253 \
    dst-port=9921 protocol=tcp to-addresses=192.168.10.1 to-ports=9921
add action=dst-nat chain=dstnat comment=server-openvpn dst-address=\
    192.168.2.253 dst-port=1194 protocol=udp to-addresses=192.168.10.1 \
    to-ports=1194
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.2.254
/ip service
set telnet address=192.168.10.0/24 disabled=yes port=7123
set ftp address=192.168.10.0/24 disabled=yes port=7121
set www address=192.168.10.0/24
set ssh address=192.168.10.0/24 port=7021
set api disabled=yes
set winbox address=192.168.10.0/24
set api-ssl disabled=yes
/ppp secret
add name=*** profile=l2tp service=l2tp
add name=*** profile=l2tp2 service=l2tp
add name=*** profile=ovpn service=ovpn
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=IU1LCU-QTH
/system leds
set 0 interface=wlan1 leds=led1,led2,led3,led4,led5 type=\
    wireless-signal-strength
set 1 leds=poe-led type=poe-out
/system scheduler
add interval=30m name=APRS on-event=" /system script run aprs" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=sep/04/2022 start-time=00:00:00
/system script
add dont-require-permissions=yes name=aprs owner=iu1lcu policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
    !rsc\r\
    \n# RouterOS script: aprs\r\
    \n\r\
    \n# --- Begin customization ---\r\
    \n:local aprsCall \"IU1LCU\";\r\
    \n:local aprsSsid \"RB\";\r\
    \n:local aprsPass \"***\";\r\
    \n:local aprsLat \"***\";\r\
    \n:local aprsLon \"***\";\r\
    \n:local aprsComment \"Mikrotik\"\r\
    \n:local aprsSymbol \"I\";\r\
    \n# --- End customization ---\r\
    \n\r\
    \n# HTTP Post to APRS-IS\r\
    \n# Note: Requires line feed at beginning of http-data\r\
    \n\r\
    \n/tool fetch keep-result=no http-method=post http-header-field=\"accept-t\
    ype: text/plain,content-type: application/octet-stream,content-length: 93\
    \" port=8080 url=http://srvr.aprs-is.net/ http-data=(\"\r\
    \nuser \$aprsCall pass \$aprsPass vers mikrotik\r\
    \n\$aprsCall\".\"-\".\"\$aprsSsid\".\">APRS,TCPIP*:=\$aprsLat\".\"/\$aprsL\
    on\".\"\$aprsSymbol \$aprsComment\")"
I do not see anything strange except “b” for 2.4 and old wpa active.
For fix paste this on terminal:
set profile1 authentication-types=wpa2-psk eap-methods=passthrough supplicant-identity="MikroTik"
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n
But for problems on that sites, I do not see anything strange…
One friend of mine tell me about something in ip-firewall and in the top tab “connection” where are the timeout limit but he didnt remember wich parameter is, i see also some similar problem on forum they talk about MTU (i dont know what is)
Do not matter.
Your firewall timing is right.
The problem can be your ISP or the device you use, if “touched” like RouterBOARD…
I hope this is still disabled…
/ip firewall mangle
I find in another forum post this command
 ip firewall/ mangle/ add action=change-mss chain=forward new
-mss=clamp-to-pmtu passthrough=yes \ protocol=tcp tcp-flags=syn
i honestly dont know what is (im not a mikrotik expert) but now is working
i hope this can be helpful for other people
very thank you rextended 73
