https
Dear MikroTikers,
I have a simple question (I hope) I have a hotspot on my RB 1000 and as you all know it uses http by default is there anyway to use https for the hotspot authentication.
many thanks
you can do it…just create or buy the certificates, import it and configure the hotspot for https login.
PS: Search on this forum, this topic was talked
M.
