When will you add support for the Huawei 3372-320 modem?
It’s half-broken supported in the new beta version 7.
In stick mode (if you can reflash your stick) it already works in 6.
What’s ‘half-broken’ about it?
If I remove the 3372 and plug it back in, I have to reboot for it to work.
Here’s an article that may be helpful. It demonstrates the mode switch.
https://pfstore.com.au/blogs/guides/reflash-huawei-e3372h-usb-modems-for-pfsense-opnsense
# Available options
AT^SETPORT=?
# Whats the current order of network, CD emulation etc
AT^SETPORT?
# ff= no modeswitch
# 1 = modem, 12 = pc ui, 16 = ncm, A1 = cd, A2 = SD
AT^SETPORT="FF;1,12,16,A1,A2"
# Or, Disable the cd emulation
AT^SETPORT="FF;1,12,16"
Thank you but I tried a hundred times to do the stick mode firmware and can’t get it to go into loading mode. RIP.
I tried it with a powered OTG cable in HAP AC2 and no good.
