yesterday I bought one Huawei E1692 for 3G connection. Although is not listed in supported hardware (is it the same with E169 ?) it have been recognized, but I cannot connect…
I have tried several options, and I have found that channel 0 is for data, and channel 1 for information.
I have removed pin request for less trouble.
I have found the correct APN string (“gint.b-online.gr”) for my provider (WIND in Greece).
I have successfully scanned for networks (using either AT Commands, either console utility).
I have enough signal for connection. When I use the same modem on my laptop, it connects.
I have tried to dial using AT Commands, and dialing was successful (as modem reported).
… but connection flow freezes at “ppp-wind: reseting link…”.
I changed the data channel to 1 (as information channel) but with no luck. Now, after “reseting link…” it brings repeatedly “initializing modem…” and “dialing out…”.
For dialing phones, I have tried, nothing, “991#", "99*1#”, “*99#1”, and maybe others with no success.
