HUAWEI E3272 - 0x14db - PROBLEM!
I bought the Huawei E3272 and i thought everything was fine!
first of all i checked the /resources usb devices and the device id of my lte stick is 0x14db
that mean i should work…
lte interfaces is also running!
THE PROBLEM IS:
If i want to scan for networks, the router prints out the following error:
please hepl me! :wink:
I’m having the same problem, can I change the Device ID ???
In order for you to be able to connect through the LTE interface, you add a DHCP Client that is directed to the LTE and masquared in the interface in the firewall tab. You will access the interface of the Stick LTE through IP 192.168.1.1, there you will be able to configure the operator and have 4G access
