Huawei E3372 "Modem does not have serial interface"
Hello!
Router RB750UP (6.19 v) with Huawei E3372.
Modem E3372 determined like lte1 interface. Internet work. Modem work.
Modem detected in Resources —> USB, but not get port. System—>Ports is Empty.
In “Lte Info” writes "Couldnt start - Modem does not have serial interface!" I cant see any information from modem - Model, Current Operator, Signal Strength.
Can you help me?
Modem revision: 22.286.53.01..161
Did you try with RouterOS 6.8? Did you add dhcp client for lte interface?
Have you found any solution for this issue, yet? I have the same problem and I would prefer to be able to watch LTE info from inside Mikrotik and now connected to Huawei interface.
Thanks in advanced.
