Huawei K5160 LTE interface
Ciao!
I’m having some troubles with the Huawei (Vodafone) K5160 LTE dongle.
Under Windows 10, without installing any software, just creating the APN profile, the device works correctly, connecting to Internet; the LED on the dongle becomes purple and steady on.
With RouterOS 7.18 the LTE interface is created, but no connection is etablished; the LED just blink purple.
The only notable difference is that Windows reports this when the connection is established (using ipconfig /all):
   Description: Generic Mobile Broadband Adapter #18
   Physical Address: 88-87-91-**-**-**
   DHCP Enabled: No
   Autoconfiguration Enabled: Yes
   Link-local IPv6 Address: fe80::bf85:****:****:****%9
   IPv4 Address: 10.14.X.X
   Subnet Mask: 255.255.255.252
   Default Gateway: 10.14.X.X
   DNS Servers: 83.158.240.241, 83.158.240.240
   NetBIOS over Tcpip: Enabled
while RouterOS just gets a local address (192.168.8.100/24) from the dongle via DHCP. The dongle itself acts as a gateway with the address 192.168.8.1/24.
The APN is the same, with the same parameters.
Is there any special configuration I have to set up?
I’m using a Mikrotik RB750Gr3 (hEX mmips).
Thanks!
Denis
Looks like its loaded in config-less mode, apn settings from RouterOS will be ignored in this case - configure it through http://192.168.8.1
or change /interface lte settings set mode=mbim and try to load it in mbim mode.
It worked!
Actually the modem was in auto mode; setting it in mbim works perfectly.
Thank you!
