Hi all,
I’m having a problem with Huawei MU609 card.
I’m using Mikrotik RB912UAG-2HPnD, ROS v6.24, firmware 3.19.
The modem is recognized in System - Resources - Usb, but in System - Ports there is only 1 channel recognized. That is channel 0.
In Mikrotik wiki supported hardware it says:
Huawei MU609 mPCIe [92] v6.0 Data channel=4, Info channel=2, Keep info channel open MiniPCI-e
So there should be more channels available. It doesn’t work this way and I want to have separate data and info channel.
If I put in PC using USB adapter and opening Hyper terminal I see other channels.
I’ve tried with some earlier versions of ROS v6.xx but it’s the same.
Where is the problem?
