I really have a huge request because so far I had routers for v6, and something bad is starting to happen with them, with hardware.
Can anyone help me with a ready bgp filter ? I advertise 2 classes (/23 and /24), I just need a recipe on how to set their advertisement in the filter, prepend and local_pref, nothing else. Please help. I am configuring CCR2116-12G-4S + with RoS 7.2.1.
And please do not refer me to the guides, because I do not have time for this, the whole network is hanging by a thread. I will be grateful for your help.
@method just a hint, before putting a major upgrade in production, it’s best practice to perform extensive testing in a lab environment and also have a working rollback plan. If you’re really in a hurry and unable to perform this task yourself, I’d take @anav’s advice and hire a consultant the first thing tomorrow morning.
Hence my suggestion for a consultant or find someone who is actually trained. Such hints would have been on the first test and reinforced every test thereafter. Would have been like telling an astronaut, check your spacesuit prior to exiting the space capsule DOH!!
If there still is a working config for v6, my advice is to first roll back and then try to convert the filters to v7 in a test environment separate from production.
Then you can ask questions in the forum specifically for v7 until everything works as intended without haste.
Jumping head first from the rock to the unknown deep and visibility water is very dangerous and could make you sick. No doubt.
You should think about possible problems in advance not after breaking neck. Do not blame volunteers for your problems. Call ER team.
Yet NOW you want the same user population to assist you on that config which was super-classified-top-notch-secret-only-for-me ??
And you can not see that you harvest what you planted some time ago ?
I think you have other problems then only a configuration misbehaving …
I found a solution for ipv6 bgp in RoS7 , but that was wiki for v6. and you, my friend, back off and dont talk to me.
I would blame the RoS 7 but unfortunately this CCR cannot be downgraded, that’s why I asked. And you are picking on and searching for my nickname on the forum to prove your point. Pathetic.
