As I install UM at a few clients and let them manage the users.
Since most use transfer limit as opposed to time limit, can we enter a human readable transfer limit for eg. 500Mb instead of 524288000 (bytes)?
Ekkas
Ekkas
New User Manager supports M and K letters. Old User Manager should support such option as well.
Neither options work in UM 4.5:
512M
512 M
512MB
512Mb
and so on…
If you go back into the user, it just shows 512 (bytes?)
Ekkas
I have older version and m is saved there.
However, you should try user manager test package, the feature should work there.
