Hw Offload unavailable with bridge+vlan
I found a bunch of forums/wikis/tutorials which describe issues that would prevent hw offload, but I don’t see any of the common mistakes in my config. I’m not even sure I really need hw offload, but I’m afraid I may have done something wrong if that is not working. I have a HEX (MT7621A). Here is (I think) the relevant config:
[admin@MikroTik] > /interface bridge print
 0 R name="bridge1" mtu=auto actual-mtu=1500 l2mtu=1596 arp=enabled arp-timeout=auto
     mac-address=18:FD:74:FC:C3:E6 protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=yes
     ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6
     vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-only-vlan-tagged ingress-filtering=no
     dhcp-snooping=no
[admin@MikroTik] > /interface bridge vlan print
Flags: X - disabled, D - dynamic
 #   BRIDGE                    VLAN-IDS  CURRENT-TAGGED                  CURRENT-UNTAGGED
 0   bridge1                   1-6       bridge1
                                         ether2
[admin@MikroTik] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE             BRIDGE             HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0     ether2                bridge1            yes    1     0x80         10                 10       none
 1 I   ether3                bridge1            yes    1     0x80         10                 10       none
 2 I   ether4                bridge1            yes    1     0x80         10                 10       none
 3 I   ether5                bridge1            yes    1     0x80         10                 10       none
[admin@MikroTik] > /interface vlan print
 #   NAME                                MTU ARP             VLAN-ID INTERFACE
 0 R BOOTSTRAP                          1500 enabled               1 bridge1
 1 R CAMS                               1500 enabled               5 bridge1
 2 R GUEST                              1500 enabled               3 bridge1
 3 R INFRA                              1500 enabled               6 bridge1
 4 R IOT                                1500 enabled               4 bridge1
 5 R MAIN                               1500 enabled               2 bridge1
[admin@MikroTik] > /interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1                              ether            1500  1596       2026 x:E5
 1  RS ether2                              ether            1500  1596       2026 x:E6
 2   S ether3                              ether            1500  1596       2026 x:E7
 3   S ether4                              ether            1500  1596       2026 x:E8
 4   S ether5                              ether            1500  1596       2026 x:E9
 5  R  BOOTSTRAP                           vlan             1500  1592            x:E6
 6  R  CAMS                                vlan             1500  1592            x:E6
 7  R  GUEST                               vlan             1500  1592            x:E6
 8  R  INFRA                               vlan             1500  1592            x:E6
 9  R  IOT                                 vlan             1500  1592            x:E6
10  R  MAIN                                vlan             1500  1592            x:E6
11  R  bridge1                             bridge           1500  1596            x:E6
[admin@MikroTik] > /interface list print
Flags: * - builtin, D - dynamic
 #   NAME                            INCLUDE                            EXCLUDE
 0 * ;;; contains all interfaces
     all
 1 * ;;; contains no interfaces
     none
 2 * ;;; contains dynamic interfaces
     dynamic
 3 * ;;; contains static interfaces
     static
 4   list_bridge
 5   list_lan
 6   list_vlan
 7   list_wan
[admin@MikroTik] > /interface list member print
 #   LIST                                             INTERFACE
 0   list_bridge                                      bridge1
 1   list_lan                                         ether2
 2   list_lan                                         ether3
 3   list_lan                                         ether4
 4   list_vlan                                        MAIN
 5   list_wan                                         ether1
 6   list_lan                                         ether5
 7   list_vlan                                        GUEST
 8   list_vlan                                        IOT
 9   list_vlan                                        CAMS
10   list_vlan                                        INFRA
[admin@MikroTik] > ip firewall nat print
 0    chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
Should I be concerned that the HW offload indicator is not set? Is there anything obviously wrong so far? Thanks!
Which ROS version? VLAN-enabled bridge HW offloading on MT7621 is only available in ROS 7.1 and newer.
Ah, that’ll do it. I’m at the latest long-term release, which I didn’t realize is still v6.x. Thanks :slight_smile:
