I’ve enabled “hw=yes” on the ether ports, however in the GUI, it doesn’t actually have that ticked when adding to bridge1? If however you go back to making a port connected to “bridge” then the HW offload is ticked. There is no way for you to tick “HW. Offload” in “Status” too. You can however tick “Hardware Offload” in “Bridge > Ports > General” This option has been ticked.
Apologies. It’s the CRS328-24P-4S+RM
Why do I even need to create a “bridge=1” any way? It’s mentioned but I’ve got no idea why I need to bother with creating a separate bridge , when all I want it to do is act like a Cisco 2960G switch, that provides PoE but at a far cheaper price (and less fan use/power)
Awesome. It’s just that Mikrotik’s own guide said to add it in, and I was like “But why?” I’ll try just using the default bridge, given it offloads to the switch, so therefore should be “wire speed” and not done in software.
Mikrotik (And other vendors) assume the reader will have some technical knowledge / experience, the wiki is nt “Dummy Guides” as they have no way of knowing the multiple configs out there in the world.
It might be that you have reset your device with no configuration and wants to create all from scratch, hence Mikrotik mentions to create a bridge.
If there is already a bridge as per default config, then just skip the step…
