HWMP and switches
Are you using HWMP in your network?
  • Yes (As big network 200+ Mikrotiks)
  • Yes (As a small network 1 - 200 Mikrotiks)
  • Yes (Instead of OSPF)
  • No
0 voters
I read the wiki. I think I understand this but I want to clairify. I attached an example. Since these switches are not hwmp, will this cause a loop in the network? I am thinking they will cause a loop.
Who is all using HWMP? I would like to chat with you. If I end of using HWMP. I would like to make better documentation.
I need to have a computer full loop with 100% hwmp in order to work as a circle. Correct?
Hi, have you solved your problem?
I’m trying to make a similar thing, but it doesn’t work…
What does “HWMP” stand for?
I believe it stands for hybrid wireless mesh protocol. Its mesh.
