Hybrid VLAN port on LCAP
Im a noob/its a hobby in regards to networking, so please be patient, stupid questions will come towards you :slight_smile:
Equipment:
Router - RB5009UB+S+
Unify with:
  • Unify cloud key
  • Switch - 2 x Unify US-8-60w
  • AP - 3 x Unify UAP-IW-HD
What I want to obtain:
4 ports from RB5009 will be in LCAP (2 for each us-8-60) with hybrid VLAN ports. Base IP 10.10.0.0 for equipment communication and n x VLANs to be tagged on the AP SSID. All ports should be with HW (using switch chip) LCAP and n x VLAN. All VLANs should have internet.
What I want to obtain security wise:
VLANs should not be able to communicate with router configuration interface (example base ip 10.10.0.1 or vlan ip 10.10.30.1). VLANs should not be able to communicate with each other or VLAN1.
  • only if I specify ip/port/protocol
  • one vlan will be for IoT wifi and it needs all bangs and whistles ICMP, MCAST…
    They will be cut off from cloud when I finish the config and will be using Home Assistant as access point
What I don`t understand:
  • fasttrack-connection - should I keep it for IoT devices or not?
  • for the bellow config, why I cannot get ip on VLAN66
Thanks in advance for your help :slight_smile:
This is what I have now:
# 2023-10-17 00:54:14 by RouterOS 7.11.2
# model = RB5009UG+S+
add admin-mac=**ELIDED** auto-mac=no comment=LAN_BRIDGE name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] comment=PORTS_INTERFACE mac-address=**ELIDED** name=ether1-WAN
set [ find default-name=ether6 ] rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether7 ] name="ether7 - Bond"
set [ find default-name=ether8 ] name="ether8 - Bond"
set [ find default-name=sfp-sfpplus1 ] comment=SFP+_INTERFACE
/interface bonding
add comment=LCAP_INTERFACE mode=802.3ad name=bond_1_7-8_2gb slaves="ether7 - Bond,ether8 - Bond" transmit-hash-policy=\
    layer-2-and-3
/interface vlan
add interface=bond_1_7-8_2gb name=vlan20 vlan-id=20
add interface=bond_1_7-8_2gb name=vlan30 vlan-id=30
add interface=bond_1_7-8_2gb name=vlan66 vlan-id=66
add interface=bond_1_7-8_2gb name=vlan80 vlan-id=80
add comment=WAN_INTERFACE_LIST name=WAN
add comment=LAN_INTERFACE_LIST name=LAN
add comment=VLAN_INTERFACE_LIST name=VLAN
add name=default-dhcp ranges=10.10.0.100-10.10.0.254
add name=dhcp_pool_vlan20 ranges=10.10.20.200-10.10.20.254
add name=dhcp_pool_vlan30 ranges=10.10.30.200-10.10.30.254
add name=dhcp_pool_vlan66 ranges=10.10.66.200-10.10.66.254
add name=dhcp_pool_vlan80 ranges=10.10.80.200-10.10.80.254
add add-arp=yes address-pool=default-dhcp interface=bridge lease-time=10m name=bridge-defconf
add add-arp=yes address-pool=dhcp_pool_vlan20 interface=vlan20 lease-time=10m name=dhcp_vlan20
add add-arp=yes address-pool=dhcp_pool_vlan30 interface=vlan30 lease-time=10m name=dhcp_vlan30
add add-arp=yes address-pool=dhcp_pool_vlan66 interface=vlan66 lease-time=10m name=dhcp_vlan66
add add-arp=yes address-pool=dhcp_pool_vlan80 interface=vlan80 lease-time=10m name=dhcp_vlan80
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge interface=bond_1_7-8_2gb
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge untagged=bond_1_7-8_2gb vlan-ids=66
/interface detect-internet
set detect-interface-list=all
add interface=bridge list=LAN
add comment=WAN_LIST interface=ether1-WAN list=WAN
add interface=vlan66 list=VLAN
add comment=VLAN_LIST interface=vlan20 list=VLAN
add interface=vlan30 list=VLAN
add address=10.10.0.1/24 comment=defconf interface=bridge network=10.10.0.0
add address=10.10.20.1/24 interface=vlan20 network=10.10.20.0
add address=10.10.30.1/24 interface=vlan30 network=10.10.30.0
add address=10.10.66.1/24 interface=vlan66 network=10.10.66.0
add address=10.10.80.1/24 interface=vlan80 network=10.10.80.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1-WAN
add address=10.10.0.0/24 comment=defconf-address dns-server=10.10.0.1 gateway=10.10.0.1
add address=10.10.66.0/24 dns-server=10.10.66.1 gateway=10.10.66.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=10.10.0.1 comment=defconf name=router.lan
/ip firewall address-list
add address=10.10.66.0/24 list="IoT - 66"
add address=10.10.0.0/24 list="Lan - List"
add address=10.10.20.0/24 list="Containers - 20"
add address=10.10.30.0/24 list="Containers - 30"
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow Full Access" disabled=yes in-interface=bridge
add action=accept chain=forward comment="VLAN Internet Access only" connection-state=new in-interface-list=VLAN \
    out-interface-list=WAN
add action=accept chain=forward comment="VLAN Internet Access only" connection-state=new in-interface-list=LAN \
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=\
    new in-interface-list=WAN
/ip firewall mangle
add action=set-priority chain=postrouting new-priority=from-dscp-high-3-bits passthrough=yes
add action=redirect chain=dstnat dst-port=53 protocol=tcp to-ports=53
add action=redirect chain=dstnat dst-port=53 protocol=udp to-ports=53
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set www-ssl certificate=webfig disabled=no
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set allow-disable-external-interface=yes enabled=yes show-dummy-rule=no
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1-WAN type=external
/tool mac-server
/tool mac-server mac-winbox
when you get rid of the bridge playing silly dhcp games and create a vlan for that subnet, I would be willing to help.
Ok.
By VLAN subnet you are talking about VID1?
If not, then I need help :disappointed_face:
Ok,
Some other help please.
Anyone?!
