csr
October 18, 2022, 7:32am
1
Source:
Windows Server 2016 standard, Hyper-V
Chr 6.48.6
Two interface: ethernet and bridge with it.
Mac address on interface and bridge (admin-mac) the same from Hyper-V virtual machine (00:15:xx:xx:xx:xx)
In neighbor list in other MT i can see chr with two mac addresses:
mac from chr (00:15:xx:xx:xx:xx) and mac from Hyper-V server interface.
Why is the host machine mac visible?
csr
December 27, 2022, 10:17am
2
Has no one face with this problem?
csr
February 28, 2023, 6:43pm
3
On this CHR router, there are only two interfaces connected from the HV. Their “native” mac addresses start with “00:15:5D”.
There are no other interfaces (bridge etc).
Where the “E4:11:5B” addresses come from is unknown. There is no mention of these macs in the configuration.
Where do wrong mac addresses come from? How do I get rid of them???
interface/export verbose terse
/interface ethernet set [ find default-name=ether2 ] advertise="" arp=enabled arp-timeout=auto auto-negotiation=yes cable-settings=default disable-runnin
g-check=no disabled=no full-duplex=yes loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=00:15:5D:05:16:20 mtu=
1500 name=ether-mgmt orig-mac-address=00:15:5D:05:16:20 speed=100Mbps
/interface ethernet set [ find default-name=ether1 ] advertise="" arp=enabled arp-timeout=auto auto-negotiation=yes cable-settings=default disable-runnin
g-check=no disabled=no full-duplex=yes loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=00:15:5D:05:16:0F mtu=
1500 name=ether1 orig-mac-address=00:15:5D:05:16:0F speed=100Mbps
/interface list set [ find name=all ] comment="contains all interfaces" exclude="" include="" name=all
/interface list set [ find name=none ] comment="contains no interfaces" exclude="" include="" name=none
/interface list set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" include="" name=dynamic
/interface list set [ find name=static ] comment="contains static interfaces" exclude="" include="" name=static
/interface lte apn set [ find default=yes ] add-default-route=yes apn=internet authentication=none default-route-distance=2 ip-type=auto name=default use
-network-apn=yes use-peer-dns=yes
/interface macsec profile set [ find default-name=default ] name=default server-priority=10
/interface wireless security-profiles set [ find default=yes ] authentication-types="" disable-pmkid=no eap-methods=passthrough group-ciphers=aes-ccm gro
up-key-update=5m interim-update=0s management-protection=disabled mode=none mschapv2-username="" name=default radius-called-format=mac:ssid radius-eap-ac
counting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-user
name static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-sta-private-algo=none static-transmit-key=key-0 supplicant-identi
ty=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=aes-ccm
/interface bridge port-controller
# disabled
set bridge=none cascade-ports="" switch=none
/interface bridge port-extender
# disabled
set control-ports="" excluded-ports="" switch=none
/interface bridge settings set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/interface detect-internet set detect-interface-list=none internet-interface-list=none lan-interface-list=none wan-interface-list=none
/interface l2tp-server server set accept-proto-version=all accept-pseudowire-type=all allow-fast-path=no authentication=pap,chap,mschap1,mschap2 caller-i
d-type=ip-address default-profile=default-encryption enabled=no keepalive-timeout=30 l2tpv3-circuit-id="" l2tpv3-cookie-length=0 l2tpv3-digest-hash=md5 !
l2tpv3-ether-interface-list max-mru=1450 max-mtu=1450 max-sessions=unlimited mrru=disabled one-session-per-host=no use-ipsec=no
/interface lte settings set firmware-path=firmware mode=auto
/interface ovpn-server server set auth=sha1,md5 certificate=*0 cipher=blowfish128,aes128-cbc default-profile=default enable-tun-ipv6=no enabled=no ipv6-p
refix-len=64 keepalive-timeout=60 mac-address=FE:A2:B0:FD:0C:18 max-mtu=1500 mode=ip netmask=24 port=1194 protocol=tcp redirect-gateway=disabled reneg-se
c=3600 require-client-certificate=no tls-version=any tun-server-ipv6=::
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=default enabled=no keepalive-timeout=60 max-mr
u=1500 max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any verify-client-certificate=no
/interface wireless align set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 fr
ames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" caps-man-names="" certificate=none discovery-interface
s="" enabled=no interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no stre
aming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper set channel-time=200ms multiple-channels=yes receive-errors=no
