I am lost on how to get internet access
Ok, this is my first post so please be gentile. I have a 450G with 4.11 on it. I have my modem connected to Eth5 and my network on Eth1. I have enabled a DHCP server for Eth1 and a DHCPclient for Eth5 and both are working. PCs on my network can see one another and my router can get an IP from my ISP but I cannot for the life of me get my network to see the internet.
IPs
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.1.1/24 192.168.1.0 192.168.1.255 Local
1 D 70.81.74.69/24 70.81.74.0 70.81.74.255 Public
Devices
NAME TYPE MTU L2MTU
0 R Local ether 1500 1524
1 ether2-local ether 1500 1524
2 R ether3-local ether 1500 1524
3 ether4-local ether 1500 1524
4 R Public ether 1500 1524
IP Pools
NAME RANGES
0 default-dhcp 192.168.88.10-192.168.88.254
1 dhcp-pool-1 192.168.1.2-192.168.1.200
configure:
IP DNS
IP ROUTE with a default gateway
Configure NAT. (add chain=srcnat action=masquerade out-interface=Public)
Ok, thnaks. Can you help me this the DNS and and IP route with default gateway now? Or is there a wiki link I missed? Thanks.
CONFIGURE DNS
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
    max-udp-packet-size=512 servers=195.235.113.3,80.58.0.33
CONFIGURE GATEWAY
/ip route add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=YOUR_IP_GATEWAY_TO_INTERNET scope=30 target-scope=10
I’ll give these and try and get back to you, thank you!
Question, is there anyway of forcing the default DHCP pool to be 192.168.1.xxx instead of the 192.168.88.xxx?
Yes, there’s no forcing necessary. Just adjust all the settings on the existing pool to match your network. You will, at a minimum, need to adjust the range on the IP pool as well as the DHCP server network to hand out the correct gateway and DNS server.
Ok, I still can't get this working, something else is wrong.
[admin@MikroTik] > ip address export
oct/10/2010 11:03:21 by RouterOS 4.11
software id = RS3H-VQJJ
add address=192.168.1.1/24 broadcast=192.168.1.255 comment="" disabled=no
interface=Local network=192.168.1.0
add address=192.168.1.2/24 broadcast=192.168.1.255 comment="" disabled=no
interface=Guest network=192.168.1.0
[admin@MikroTik] > ip route export
oct/10/2010 11:03:25 by RouterOS 4.11
XXX.XXX.XXX.XXX scope=30 target-scope=10
[admin@MikroTik] > ip firewall export
oct/10/2010 11:03:32 by RouterOS 4.11
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=masquerade chain=srcnat comment="" disabled=no out-interface=
Public
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
I re-ran all the setup commands and it seems to be working now. Thanks for all the help!
: D!
