i am not able to access few websites after connecting my internet line through mikrotik routerboard.
when i connect internet through mikrotik router i am not able to access few websites .but when i directly connect internet on
my pc i can access those websites that were blocked before! can anyone help me out what could be the solution!
do you use PPPoE?
Use /ip firewall mangle to change MSS (maximum segment size) 40 bytes less than your connection MTU. For example, if you have encrypted PPPoE link with MTU=1492, set the mangle rule as follows:
/ ip firewall mangle
add chain=forward protocol=tcp tcp-flags=syn action=change-mss tcp-mss=!0-1448 new-mss=1448
yes i am using PPPoE.
thanks for reply,
there are 4 mangle rules created in router dynamically. Here i am attaching snapshots.
yes i am using PPPoe, and there are 4 mangle created on router dynamically. If i disable these dynamically created mangle, do it disconnect PPPoE or it won’t affect PPPoE?
Here i am attaching screenshots
Thanks problem is solved..
i used this command
ip firewall mangle
add chain=forward protocol=tcp tcp-flags=syn action=change-mss tcp-mss=!0-1432 new-mss=1410
