I am not able to set up a queue correctly.
I am attempting to apply a speed limit to a certain IP. I do the following procedure:
I open the queue from winbox
In the general tab:
  • Name = asdfdafdsf
  • Target Address = Users IP address (they all have 2, one for the modem and one for their computer. I use the computer one)
    *Max Limits = I set them and check target upload and target download
Under Advanced:
  • Interface = all
This does not actually seem to intercept and queue any traffic. Does this only work if the mikrotik is experience more traffic than the network can handle?
Where did I go wrong?
David
Change queue type - “default-small” not working :slight_smile:
What should I change it to?
Thank you for the response!!
If you have one queue per client then not a big difference, anything except “default-small” - check out manual http://wiki.mikrotik.com/wiki/Queue#Queue_Types for more details.
Also consider moving to queue trees & PCQ http://wiki.mikrotik.com/wiki/Bandwidth_Managment_and_Queues
basic example: http://wiki.mikrotik.com/wiki/PCQ_Examples
advanced example: http://mum.mikrotik.com/presentations/CZ09/QoS_Megis.pdf
so did it help?..
maybe, ‘xen’ package is the reason?
