I am trying to integrate mikrotik router (hap ac2) as AP into an Ubiquiti network
Hello
I need to be able to create 2 WiFi:
-main wifi
-guest wifi
Main wifi must be on vlan 1 (192.168.1/24)
Guest wifi must be on vlan 2 (192.168.2/24)
Each SSIDs should be connectable both on 2.4GHz and 5 GHz.
There are working DHCP servers for both LANs (that are running on the Ubiquiti gateway)
I tried to configure it, but it is not working.
I do not know how to extract the info to list here so that you can help me .
PS: mikrotik router is running RouterOS 6.49.8 (long-term)
LE: some months ago I spent several nights trying to get the job done. Not a chance. So I left it with just the main WiFi.
Now I thought to myself: with all these AI arround, why not ask them to do the job.
I tried with ChtGPT, but it also couldn’t do the job.
LLE: Solved
Please advise.
Many thanks in advance.
Danny
