If these are new units under warranty, then you should contact your reseller for getting a replacement. If they are second-hand, then the seller screwed you …
Either NAND chips are all faulty or they are missing altogether (there should be 16MB FLASH storage). License is “burned” on the NAND chips, it’s not there hence the “demo license expired” message.
