I found the error with my wifi…
The access points I bought are not able to work when set to Germany.
No matter which channel I configure, they all are NOT SUPPORTED
And by the way… nowhere I found it written, that I have to delete all cap interfaces, before they can get a provision.
When they are provisioned, they never get an update / change.
they do mostly the opposite of what I do. I configure them for 5 GHz, they provision to 2.4
I provision config 1, disable 2, and what do they get? config 2…
So, the only way seems to be, setting something and try all settings out, until I get, what I need.
As soon as I apply a config with Germany as country, all frequencies, all channels etc are unsupported.
And then there are countries, where at least 1 of 2 identical access points doesn’t refuse to work.
Post an example of how you determine “unsupported”. is there some error message? It is possible you don’t see 5GHz, because due to EU regulation, radar detection process happens some 10 min after booting. Try to not reboot and just wait.
OP possibly messed around with provisioning rules and tries to provision cap-2ghz-radio with 5ghz-configuration and other way round. That’s the most common cause for “no supported channel” if you use the forum search function. e.g. http://forum.mikrotik.com/t/no-supported-channels/162032/1
Most likely software is not faulty and your device fully supports Germany. Post full config and a picture of the issue. We can not help without this info
On some (older) Mikrotik models wifi1 was 2.4 GHz, and wifi2 was 5 GHz, in more recent one they are the opposite, so - especially when following an older tutorial/forum topic/video - it is easy to invert the two by mistake.
That is the sense of “rearranged” in this context.
160 Hz is a possible width of band on some devices and also in some countries only, ignore the references to it.
Many thanks for that really useful declaration! Honestly, that’s more than important to me.
Could you please tell me where I see wifi1 and wifi2 in my crs112 config?
