Hello to all, my question is: i can install the dude on rb951 with 128 of ram?
yes, you can install dude on router os
where i can download it?
it is better if you run dude server on windows.
i didn’t find dude server for 900 series
there isn’t the versione for this rb ![]()
You can install the MIPS-BE version on each MIPS-BE routerboard:
http://download.mikrotik.com/dude/4.0beta3/dude-4.0beta3-mipsbe.npk
i try it thnks ![]()
trottolino1970,
you’re welcome. assuming that you have a usb port in your router, you can use a usb pendrive to store dude settings (SYSTEM>STORES)
let us know how it works out for you.
trottolino1970,
wonderfull idea, i try in the next day
ok, i instal it but how i can configure?
hello to all.
i install it but my rb go reboot every time ![]()
Hi, you’re probably need to send it back to the distributor. The routerboad and Dude work fine as long as you don’t reboot it. After reboot it goes into a infinite restart loop. Unfortunately I have experienced the same with a 951G last week and 6.15rc. I have flagged this post as a bug report to MT Tech Support.
yes i know that dude and mk work fine but as you experience no in 951, loop reboot.
thanks for the reply and have you a beautiful day ![]()
Ok, I’ll call it a beatiful day once the RB will be replaced. By the way which ROS version did you use on your 951?
6.4
Inviato dal mio GT-I8190N con Tapatalk 2
Hi to all
we are in 2016 , and my rb951 version now is 6.35.
pleas help me to now, which version must download from download page.
You cannot install the dude on it
Inviato dal mio SM-G361F utilizzando Tapatalk
