I can not upgrade from 5.26 to 6.x x86
Hello!
I have a problem
RouterOS 5.26 on x86. I want to upgrade to 6.6
After update i get kernel panic
i updated to 6.0 b1 and b2 it’s ok
i updated to 6.0 b3, 6.0 rc1, 6.1 - kernel panic
reset configuration… and no effect, kernel panic on b3 and newer
on /system licence: upgradable to v6.x
how to update by latest version?
Thanx!
Try to install with netinstall or CD install.
Nothing helps.
Wanted to clarify that I was doing it for Citrix XenServer 5.6
