Not sure how documentation helps, I have read it I understand and they are compleate.
I have conectivity to the internet and all OS Routers and public IP. I can ping anything outside my local network.
I just can’t ping some address.
When I do an Ip-Scan I get the following address.
192.168.2.6
192.168.2.11
192.168.2.18
192.168.2.20
192.168.2.22
192.168.2.86
192.168.2.103
192.168.2.104
192.168.2.105
192.168.2.114
192.168.2.121
192.168.2.122
192.168.2.164
192.168.2.169
192.168.2.219
192.168.2.223
192.168.2.225
192.168.2.235
I can ping some of the address but not others
For example I can ping 192.168.2.106 and 192.168.2.219. These are clients with active sesions.
All of the Address bellow 100 represent CPE equiment. I can not ping them.
Ping address of active clients about 100 in this case only 106 and 219. The other values I can not ping.
Ping 192.168.2.22 – You will see some percentaged of the packets active.
4 http://192.168.2.22 you will get to the log in page for the CPE device at this address. I have only tested for this one address.
One additonal Question is I am not sure what you mean by
“1. if you run as hotspot service you must plan your network as Transparant Network”
I assume my ISP has taken care of this part of the Hotspot development.
As far as i understood, Transparant Network is same mean Will make Roaming User Network, or you have Broadcast network over AP2AP, AP2CPE blah...blah..blah... far far away.. . . .
But by Broadcast Network isn't good idea when your plan as Large Network. by Routing is recommended.
this e.g one subnet ip-binding for:
/ip hot ip-bi add address=88.88.88.88.0/28 type=bypa
Just becarefull, user or CPE under hotspot server will unreachable when user or cpe aren't authenthicated.
