I can Use RB/133C and R52
i have one AP with 24DBi omni antenna at our internet base station and we are Using Radmax 400 milie watt and we are just connect our customer to put one AP wireless Client and Connect this Wireless Client to Our AP
Actually i want to User Mikrotik Product like i use RB/133C and add R52 wireless card and put this setup on client side then
i Can configured this product as a Wireless Infrastructure(AP Client) ?
and i Can connect this mikrotik Client to my AP Wireless ?
And Also For this Mikrotik Wireless Card How Much Distance i archived ?
Pls Answer
Jip. That is the way to do it. Access point is set up as access point client CPE is set up as station. That’s the most basic setup. If your access point is a mikrotik router there are a few more options.
Lots of factors. 2.4 or 5.8 system. noise levels, line of sight and what kind of aerial at client side. If client have 18db panel with line of site, I guest you would do at least 5 km.
thanks Buddy
but i have to ask u that
i can connect mikrotik to any AP Device right ?
Can’t promise you that, but if access point use standard 802.11 a, b, g
u should be fine. Have tried D link, senao, Zinwa, and planet products. Connected fine to them. Usually it is the other way round. Some clients had a problem connecting to a mikrotik access point, but only the older models.
