I cannot connect with the RouterBoard 750 using Winbox
I have a Mikrotik RouterBoard 750 and I am trying to connect it using winbox.
I have some configuration on that router and I do not want to erase it.
I connect my computer and it get an ip address from the router, but I cannot do ping to the gateway.
When I open the winbox and try to connect, it fails.
I hope you can help me.
Did you try to connect via mac address instead of ip address?
Yes, I tried to connect using the mac address. but it fails.
I am using a new version of winbox. I do not like it so much.
The problem was solved.
I had to reset the router.
