I need to configure the Mikrotik as a LoRaWAN gateway but I cannot get it to connect to internet. I want to use LTE as the main connection to internet.
# 2024-11-04 15:25:33 by RouterOS 7.16.1
# software id = TUKJ-AZN5
# model = RB924iR-2nD-BT5&BG77
# serial number = <redacted>
add admin-mac=48:A9:8A:25:0B:87 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=iot.1nce.net authentication=pap ip-type=ipv4
add authentication-types=wpa-psk,wpa2-psk,wpa-eap,wpa2-eap group-ciphers=tkip,aes-ccm mode=dynamic-keys name=DIGIFIBRA-TCr7 supplicant-identity="" unicast-ciphers=tkip,aes-ccm
add authentication-types=wpa-psk,wpa2-psk,wpa-eap,wpa2-eap group-ciphers=tkip,aes-ccm mode=dynamic-keys name=PTAINNOV_COWORKING supplicant-identity="" unicast-ciphers=tkip,aes-ccm
add authentication-types=wpa-psk,wpa2-psk,wpa-eap,wpa2-eap group-ciphers=tkip,aes-ccm mode=dynamic-keys name=CINK_24 supplicant-identity="" unicast-ciphers=tkip,aes-ccm
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no distance=indoors security-profile=CINK_24 ssid=CINK_24 wireless-protocol=802.11
/iot bluetooth
set bt1 name=bt1 random-static-address=F3:B5:BF:FE:19:AE
/iot lora servers
add address=nam1.cloud.thethings.network name="TTN V3 (nam1)" protocol=UDP
add address-pool=default-dhcp interface=bridge name=defconf
/interface ppp-client
# A newer version of modem firmware is available!
add apn=iot.1nce.net data-channel=2 default-route-distance=2 disabled=no info-channel=4 modem-init="AT+QSIMDET=1,1;+QGPSCFG=\"priority\",1" name=ppp-out1 port=modem
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
/interface bridge nat
add action=accept chain=srcnat
add bridge=bridge interface=ether1
add comment=defconf interface=ppp-out1 list=WAN
/iot lora
set 0 antenna=uFL disabled=no gateway-id=2CF7F110531001AC
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add interface=bridge
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
