I can’t figure out how to use winbox on some RB750
I’m reseting the routerboard, but still can’t locate it on winbox, by MAC or IP… Whats happening?
Please someone explain
What port on the RB do you connect to?
How do you reset the device?
https://drive.google.com/file/d/19w9wDrRFNb7Ceosyh09j8S_F2GvjU8rV/view?usp=drivesdk
Thanks for reply, please check atched image
I connect rb on first port
If your computer is connected to port 1 (which is configured to be the WAN port in a default configuration), you won’t be able to connect. Make sure it is connected to port 2 - 5. Other question remains…how do you reset the RB?
my computer is connected to port 2.and i already tried in port 5,I reset RB from the reset button
Just for giggles set your PC an IP address of 192.168.88.5 with network of 192.168.88.1 and 255.255.255.0 and see if it detects the router via winbox.
In addition, disable any virtual and physical interface that you have enabled on your computer, except your Ethernet port to your RouterBOARD.
Regards.
