I can't get apple devices to connect (7.20.8)
[admin@MikroTik] /interface/wifi> /interface wifi print detail
Flags: M - master; D - dynamic; B - bound; X - disabled, I - inactive, R - running
 0 M B  default-name="wifi1" name="wifi1" l2mtu=1560 mac-address=78:9A:18:82:45:79 arp-timeout=auto radio-mac=78:9A:18:82:45:79
        configuration.mode=ap .ssid="test"
        security.authentication-types=wpa2-psk,wpa3-psk .encryption=ccmp-256,gcmp-256 .group-key-update=1h .passphrase="testtest"
        .disable-pmkid=yes .wps=disable interworking.realms=""
        datapath.client-isolation=no
        channel.frequency=2412-2462:5 .width=20mhz .skip-dfs-channels=disabled .deprioritize-unii-3-4=yes
I cannot get my iPhone to connect. I can get linux devices and other iot devices to connect.
Unset this value:
Is everything correct here?
Try to unset these values - leave it blank.
Also set this to 2412-2472:25
And like erlinden said - unset this too.
umm just do a wireless settings reset and start fresh. like others said, you have all kinds of strange settings for no apparent reason.
