Hello my friends
i have problem with logging to my server or my router board
i can’t log from the winbox when i’m useing wireless
but when i’m USING THE lan. i log so normaly
why plz
and i have another problem but after i fix it i will try to explain about the other problem
plz help me in this
i want log to my server from the wireless connect
the error msg is
time out
can u pls write your config…maybe your snmp isn’t correct
i will explain everything
i have pure connection with REAL IP : 192.168.16.2
GETWAY: 192.168.16.1
i config my MikroTik server to give DHCP 192.168.0.1/24
after i connect from the wireless i can’t se my WINBOX
and when i se it from the lan , i connect so easy from the WINBOX
also , the signal
signal is fallen down too mch
and it’s ROUTERBOARD MikroTik 344
Hyberlink Antenna 15 DBi
i need help for god sake
can you ping it’s IP? can you telnet into it? if no, probably the IP addresses are wrong. Paste “/ip address print” and “ipconfig” from windows.
