I can't open the ports forwarding!
Hi everyone, I just bought a new mikrotik router, I am very new in this environment (in configuring the mikrotik routers), in essence, I have a server, and I created a virtual machine with Hyper-V, which was connected through one virtual switch to the Server network, the ip of the virtual machine is 192.168.88.102. The server ip is 192.168.88.252.
the ip of the mikrotik router is 192.168.88.1
I have to open port 80, 8080, 2087, 2083, 443 in TCP
but I can not! I have tried every command and method, please help me.
Thank you. I leave you the compact export of the router configuration, practically there are the default settings and I only configured the PPPoE connection in eth1.
And also… how can i configure the wireless?
# apr/11/2020 14:48:21 by RouterOS 6.43.16
# software id = DI0N-3PZP
# model = RB3011UiAS
# serial number = B88E0BB9A60E
add admin-mac=C4:AD:34:2F:39:49 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    password=mypassword*** service-name=EOLO use-peer-dns=yes user=WA3784783526
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add action=dst-nat chain=dstnat comment=WebServer dst-port=80 protocol=tcp \
    to-addresses=192.168.88.102 to-ports=80
/ip service
set www address=192.168.88.0/24
/lcd
set time-interval=daily
/system clock
set time-zone-name=Europe/Rome
/tool mac-server
/tool mac-server mac-winbox
Error
192.168.88.0
Should be
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
Missing
in-interface-list=WAN to-addresses=192.168.88.102 to-ports=80 (if the to port is the same as the destination port, not required its implied)
Thanks! It’s work, but port 80 doesn’t work, because when I execute the connection via HTTP I see Webfig, how I can disable that? Thanks again, have a good day!
Yes but are you trying to access the server from within the LAN?
If so just use the LANIP of the server or if you want to test it ‘from the outside’ get a buddy to test it…
However if you want to force users on your LAN to access the server by using the WANIP of your router that is called hairpin NAT and requires some additions/modifications
Hi, I tried to access from the outside and it works, many thanks. However, if possible, I would like to disable the Webfig and continue using WinBox.
Thanks.
Best Regards.
