I can't ping externel Ip like my Gateway !
What to Do .. ! from the router i can but outside of the router i can’t !
o_hawchar86 - for anyone to really help you - you need to give a lot more info…
IP addresses and routes would be a good start.
From your description though it sounds like you don’t have route 0/0 in routing policy set to lookup table main and/or you don’t have the default route ( 0/0 ) in route table main set to go to your gateway…
Could be your masqurade rule, src/dst nat rule(s) as well.
Give us some info and we’ll help you out.
provide more info about ur interface/Ip.
  1. IP addresses - interface
  2. routes - include policy routing rules if you have any
  3. masqurade rule, src/dst nat rule(s)
Thom
DST-ADDRESS PREFSRC G GATEWAY DISTANCE INTERFACE
0 ADC 10.20.30.0/24 10.20.30.1 Network
1 ADC my ip range.152/29 my ip Cable
2 A S ;;; added by setup
0.0.0.0/0 r my gateway Cable
o_hawchar86 -
I see from your post above that you have a dynamic IP address from your cable provider as your gateway.... I haven't used that feature of route setting to setup any of the routers that I have... I use static IPs for gateways always.
There are several posts on how to use dynamic IPs for gateways - please do a search and look at the info to make sure you are getting and using the IP address given from your cable provider correctly and getting it updated as necessary as it changes....
I have IP addresses (207.115.65.xxx/xx) routed from the Telco to my gateway 66.114.146.xxx
This is print from one of my routers... Your output (print) should be very similiar except for the actual addresses/subnet masks...if not - then there is your problem..... My last octect of IP has been removed and replaced with "xx".
Thom
Using terminal mode:
command: ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.1.1/16 192.168.0.0 192.168.255.255 ether1
1 66.114.146.xxx/24 66.114.146.0 66.114.146.255 ether2
command: ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
A S 0.0.0.0/0 r 66.114.146.1 ether2
command: ip route rule print
src-address=0.0.0.0/0 dst-address=0.0.0.0/0 action=lookup table=main
command: ip firewall nat print
;;; All for now 192 to 207.115.65.xxx (this is a comment)
chain=srcnat src-address=192.168.0.0/16 action=src-nat to-addresses=207.115.65.xxx to-ports=0-65535
@ galaxynet
i added
0 chain=srcnat action=masquerade
now i can ping i don’t know what this command means, but it works can u explain me what happened
another thing is it possible to view webproxy log in log i mean what sites are currently requested and is it possible to view most visites sites in graph tool !
o_hawchar86 -
Basically masqurade or NAT changes the ‘source’ IP address of the outgoing TCP/UDP data packet. When the answering packet returns it is dst-nat’d or ‘un-masquraded’ back to the requesting IP address by the MT router.
What was happening before was that your MT router was sending your Internet requests with the IP address range of 10.20.30.0/24 - (your LAN Network) out of the router to your cable provider’s network. The MT expected the packets to get routed by the next router upstream (Cable company). Since the cable company does not route your private IP packets they (private IP address packets) just die in transit on the cable network.
What is happening now - is that all your internal IP packets have been masquraded to the same IP address as your MT router’s WAN, (from your message) “my ip range.152/29 my ip Cable”. Now the cable company’s router knows where to send packets from that IP range to/from - the MT knows it sent the packets out and tracks the connections. The returning packets get sent back to the requesting private address (LAN) requestor (un-masquraded if you will).
Sounds like you really need to read about TCP routing. Here on the Mikrotik site there are some excellent articles about TCP and routing - I don’t remember where they posted the “References” at but I know its in the docs somewhere - perhaps FAQs?. Also the Mikrotik wiki forum has some good info.
There is a way to look at the webproxy log - I don’t recall the specifics at the moment. However I do know that it only shows IP addresses not URLs. As for graphing…I don’t know the answer for that - look in the MT scripting forum and see if someone has done it before…
Thom
