Hello Guys!
I have the following problem:
I can not remotely access my Mikrotik, I have NTH With load balance, one of my WAN has published static IP address. This my code.
set 0 name=LAN
set 1 name=WAN1
set 2 name=WAN2
add address=200.13.157.132/29 interface=WAN1
add address=192.168.1.5/24 interface=WAN2
add address=192.168.55.1/24 interface=LAN
/ip firewall mangle
add chain=prerouting in-interface=LAN connection-state=new nth=2,1 action=mark-connection new-connection-mark=conn1 passthrough=yes comment="NTH1" disabled=no
add chain=prerouting in-interface=LAN connection-mark=conn1 action=mark-routing new-routing-mark=conn1 passthrough=no comment="" disabled=no
add chain=prerouting in-interface=LAN connection-state=new nth=2,2 action=mark-connection new-connection-mark=conn2 passthrough=yes comment="" disabled=no
add chain=prerouting in-interface=LAN connection-mark=conn2 action=mark-routing new-routing-mark=conn2 passthrough=no comment="NTH2" disabled=no
add chain=srcnat connection-mark=conn1 action=masquerade out-interface=WAN1 comment="NTH1" disabled=no
add chain=srcnat connection-mark=conn2 action=masquerade out-interface=WAN2 comment="NTH2" disabled=no
add dst-address=0.0.0.0/0 gateway=192.168.1.1 scope=255 target-scope=10 routing-mark=conn1 disabled=no
add dst-address=0.0.0.0/0 gateway=200.13.157.129 scope=255 target-scope=10 routing-mark=conn2 disabled=no
add dst-address=0.0.0.0/0 gateway=192.168.1.1 disabled=no
add dst-address=0.0.0.0/0 gateway=200.13.157.129 disabled=no
When I try to enter the IP address published by winbox, I get an error saying it can not connect
Try adding a firewall rule filter to accept connections in WAN2 With register in the log and have the next record
What can I do?
