I Can't set 802.1p on VLAN for DHCP [probably BUG]
I try set prority by two methods like i can read in this link: https://wiki.mikrotik.com/wiki/Vlans_on_Mikrotik_environment for the outputs requests. For example, the DHCP request is by VLAN ID: 2 and Priority 5 but the offer Mikrotik send with Priority 0 always.
(vlan 2 interface is in brVlan2 interface)
/interface bridge filter
add action=set-priority chain=output new-priority=5 out-bridge=brVlan2 passthrough=no
OR
/ip firewall mangle
add action=set-priority chain=postrouting new-priority=5 out-interface=VLAN2 passthrough=no
add action=set-priority chain=output new-priority=5 out-interface=VLAN2 passthrough=no
No one works.
Thanks for help.
snippets of config are basically not the most useful or efficient at getting at the root of the issues…
Please post config
/export hide-sensitive file=yourconfig
I think that in this case the rest of the configuration matters little. Anyway:
jan/02/1970 00:26:58 by RouterOS 6.43.12
model = 951Ui-2HnD
/interface vlan
add interface=ether1 name=vlan2 vlan-id=2
add address=192.168.2.1/24 interface=vlan2 network=192.168.2.0
/ip firewall mangle
add action=set-priority chain=postrouting new-priority=5 out-interface=vlan2
I added the address in vlan2 to make it easier to understand. I try to ping 192.168.2.2 which is a router from another manufacturer (huawei) that only accepts packages from vlan2 and priority 5. It never responds because it does not arrive with priority 5, but with 0.
I just need to use the Priority code point (PCP) bits in the IEEE 802.1Q header.
Chain should be output. Try this:
/ip firewall mangle
add action=set-priority chain=output new-priority=5 out-interface=vlan2
Thanks for the reply jprietove.
Well, now the ping if it arrives with the correct priority, but I go back to my initial problem, the ping yes, but the DHCP does not … the DHCP offer is sent with priority 0, although the DHCP Discover and the Request comes with priority 5.Therefore, the DHCP Offer never reaches its destination.
Why does it work with ICMP but not with DHCP? Maybe it’s a bug?
The export of code added is:
add name=dhcp_pool0 ranges=192.168.2.2-192.168.2.254
add address-pool=dhcp_pool0 disabled=no interface=vlan2 name=dhcp1
add address=192.168.2.0/24 gateway=192.168.2.1
Seems like DHCP bypasses most of processing on ROS and works quite directly on interfaces …
Thanks for the reply mkx
And what can be done in this case, report it as a bug? how do you do this? I need it to work like this … :confused:
send a supout and explanation of your bug to support@mikrotik.com
Did this ever get sorted out? I am having the same issue.
Wish I had found this first instead of wasting my entire evening trying to make it work.
:frowning:
I was dealing with this in multiple posts here on the forum, the solution are /interface brifge filter rules or, if you are lucky, /interface ethernet switch rules setting the 802.1p priority. If you cannot find them, come back, I’ll remember some keywords.
