Hello guys,
I made a ptp network.
Router Server on the Router Client.
When I search a given tip the client get to reach over 100Mb/s.
But when I send the same data from the server to the client router does not step 300Kb/s.
I’m doing a WDS conecxão in wlan.
What can I do to improve this sending data (Router Server to Router Client)?
Thank you.
what you just wrote, doesn’t make sense!
Hi there!
Sorry, I will try to explain what’s going on.
I have a routerboard kit model SXT 5nD r2 mipsbe with firmware version 6.15 with initial proposal to interconnect with 2 offices.
This RB are installed with 100% targeted and with 1KM of distance. We are using in bridge mode and WPS.
The scenario:
office1(192.168.2.0/24)-----RB1(192.168.88.3/24)----------RB2(192.168.88.4/24)----------office2(172.16.0.0/16)
Em both offices, I can reach all network devices, computer, printers, etc, but when I send for example one big file (1GB size) from 192.168.2.0/24 to 172.16.0.0/16, the transfer speed is around 900KB/s, 1,4MB/s (very very slow and oscillates much).
When I send the same file from 172.16.0.0/16 to 192.168.2.0/24, the transfer speed is 10MB/s (that is the correct because my switch is 10/100 yet) and the transfer stay stable until the end.
Verifications:
I have checked the cables in both sides, NIC’s, firewalls, RB configs even I did reset in both RB’s, firmware update and the problem with transfer speed continue.
Right now, I’m testing the switch in both sides and I have no idea where is the problem. If you want, I can post here the printscreen of my current RB configuration.
I appreciate your help.
Thank you very much!
Davi
It could be a radio link problem Have you tried a bw test from SXT to SXT?
Yes, I did it and SXT to SXT the speed is 100/Mbs full duplex.
In wireless comunnications the speed is working fine, but when need use cable/RJ 45 connection, in one side the transfer is slow down.
Any idea? Maybe a physical problem?
Thanks!
