Hi friends, I can’t update my current CCR1036 v6.42.6 to the new v6.45.7.
In check of updates I download the new version and reboot the system, but when it starts it will remain in the old v6.42.6.
Also download the package and send it to files and restart the system but it also comes back with version v6.42.6.
You can guide me what the problem would be.
Thank you
at least you can remove all “mipsbe” packages. A CCR is “tile” and needs only “tile” packages …
And it seems you have more than one tile package. I suggest you to remove all these packages and use check for updates on System > Packages menu.
Furthermore, you can read this: https://wiki.mikrotik.com/wiki/Manual:Upgrading_RouterOS
