I did it :(
I’ve typed a bad command and now am unable to connect to my mikrotik router.
add action=drop chain=input place-before=1
I hit enter before typing the src-address to block. You know, sometimes shit happens.
How can I recover from this situation without reseting the router to factory defaults and create the config again? The router is a RB951-2n, so no serial port is available.
Regards
you can access via mac-telnet and remove the rule
M.
Is mac-telnet enabled by default?
YES
mac-telnet saved my day! thanks a lot!
