I do not want to run, the autologin. In iOS or Android
When the hotspot login, I want to redirect WEB page displayed to the user.
However, newer devices, automatic login page was created in a simple WEB browser will be displayed.
Then, WEB page is closed without redirecting. Is there a solution?
Have you tried adjusting the “Login-By” settings in /ip hotspot profile? Try removing mac and cookie.
Thank you.
Your reply.
I tried mac and cokkie disabled.
But, autologin page then there is a pop-up in the iPhone.
In this, we can not always show the redirect page.
Mikrotik is very exciting!
I want a help.
Thank you.
Has been resolved!
walled garden Setting:
Dst-host: www.apple.com
Dst-port: 80
Path: /library/test/success.html
walled garden IP List Setting:
Dst-host:www.apple.com
Dst-port:80
Protocol:tcp
Thank you!
Good. Thanks for also coming back to post your solution.
