I am using Hap Ax2 and already have internet but cant test network speed on speedtest.net and always show server for testing in other country (specifically CITIC Telecom CPC Estonia OÜ) even though I’m in Vietnam and using my country IPS. I have to use VPN all the time to watch my country’s newspapers or want to connect to other websites, but facebook and youtube don’t need to use it. My internet very slow, thanks for reading and please help.
Please someone help me, everything from the export command:
apr/04/2023 17:43:05 by RouterOS 7.8
software id = HWJU-JB28
model = C52iG-5HaxD2HaxD
serial number = HE508TQBGC8
add dhcp-snooping=yes igmp-snooping=yes name=LAN
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=t008_gftth_khaha
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool0 interface=LAN lease-time=10h name=dhcp1
add bridge=LAN interface=ether2
add bridge=LAN interface=ether5
add address=192.168.1.1/24 interface=LAN network=192.168.1.0
add address=192.168.1.0/24 gateway=192.168.1.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat out-interface=pppoe-out1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Ho_Chi_Minh
Your ISP might have wrong geo data about your public IP, only they can fix that.
Or, your ISP has set CORRECTLY EVERYTHING.
Maybe he bought those IPs a few months ago and the IP databases used by speedtest & co. are still out of date.
Often the shitty geographic IP database services haven’t updated the geographic data yet, they always have the wrong data for years…
Search here your IP for see what is the real data registered for the IP you use:
https://wq.apnic.net/static/search.html?query=
[trích dẫn=R1CH post_id=994113 time=1680555247 user_id=9925] ISP của bạn có thể có dữ liệu địa lý sai về IP công cộng của bạn, chỉ có họ mới có thể sửa chữa điều đó. [/trích dẫn]
[trích dẫn=rextended post_id=994132 time=1680567722 user_id=68609] Hoặc, ISP của bạn đã thiết lập MỌI THỨ CHÍNH XÁC. Có lẽ anh ấy đã mua những IP đó vài tháng trước và cơ sở dữ liệu IP được sử dụng bởi speedtest & co. vẫn chưa lỗi thời. Thường thì các dịch vụ cơ sở dữ liệu IP địa lý tồi tệ vẫn chưa cập nhật dữ liệu địa lý, chúng luôn có dữ liệu sai trong nhiều năm… Tìm kiếm ở đây IP của bạn để xem dữ liệu thực được đăng ký cho IP bạn sử dụng là gì: Đường link https://wq.apnic.net/static/search.html? truy vấn=<ĐẶT IP TẠI ĐÂY> [/trích dẫn]
Tôi có Ac2 hap và cùng cấu hình nhưng kết nối với các trang web không cần VPN và luôn hiển thị máy chủ để kiểm tra tốc độ mạng ở quốc gia của tôi chứ không phải Estonia như mikrotik Ax2 của tôi.
i have an Ac2 hap and same configuration but connect to sites that don't need VPN and always show server to test network speed in my country and not Estonia like my mikrotik Ax2.
Try https://speed.cloudflare.com - see if you get same result with better location determination. Another decent but simple speed test site is fast.com which is owned by Netflix.
As a test you could clone the MAC address of the hAP ac2 to your hAP ax2. Perhaps you have a different IP address this way assigned to your hAP ax2.
Put “/export” results on forum, after remove sensitive data…
Your device can be hacked…
