i have 2 RB’s that are both ap’s 1 is for main base and the other is a repeater, i upgraded them both with ROS 4.6, after upgrading them i noticed that whenever I open my virtual AP on RB’s winbox closes. This is happening on both RB’s. This is a realli important feature and would like to get a fix for it ASAP.
it’s a confirmed bug, there will be a fix shortly
Thanks norm.
facing the same
WOW! I thought I was going crazy. Yep same here. I can access all of my Virtual APs via the terminal prompt. nonetheless this is frustrating. Any other workarounds or does 4.7 correct this problem? If so why was 4.7 pulled? Are we to see a 4.8 soon instead?
Please keep us posted. Thanks
-Sincerely
DesertAdmin
go for 5.0 it solves
Isn’t 5.0 still dev and not stable. Oh never mind it looks like 4.8 addresses the Winbox crash when you access a VAP. Well I will wait a week to see if this firm is stable enough to deploy. Thanks
-Sincerely,
DesertAdmin
Yes, 5.0 is still in beta and I think you shouldn’t use it in production.
