I have 2 questions about teknet connections:
  1. when I open telnet to my router this is what I get :
    can I change it so it will show me the name of the router?
  2. when I try to connect the router using SSH it get stuck here - doesn’t ask me for user\pass
    why is that?
you have to use SSH program to connect to SSH :slight_smile: you are telneting to the SSH port, this is not the correct approach.
Download this tool http://the.earth.li/~sgtatham/putty/latest/x86/putty.exe
O.K
and what about the first issue ?
the name of the unit in telnet?
Thanks,
You cannot change it
O.K
Thanks ,
