I have a 3011 and need help setting up wireguard
I need help setting up wireguard ony 3011
Yes...you do :grinning_face_with_smiling_eyes:
Couple of options:
WireGuard - RouterOS - MikroTik Documentation (doing it yourself)
https://www.youtube.com/watch?v=vn9ky7p5ESM&t=4s (as well)
https://www.youtube.com/watch?v=BaT965nHPsg&t=93s (that should be enough)
https://mikrotik.com/consultants?category=consultants (having someone do it for you)
I’ve got a 3011 too, setting up WireGuard on it can be a bit confusing the first time :+1:
What part are you stuck on, config on the router or client side? If you share where it’s going wrong, I can walk you through it step by step. I recently helped someone setting it up while working on a grout repair company network setup and the biggest issue was usually the peer config or allowed IPs.
