I have a problem in RB 800‎
I have a problem in RB 800 each day the device turns off and the
device does not function unless you turn off of Electricity for the
device and then turn on device works Again As enter the logo to see
the error seems to me the following word in the first line
system error critical. router was rebooted without proper shutdow …
So . what do I do about it .. Please send the solution as soon as
possible .. Now I have a network connection problems
Two things you need to try:-
    1. Change the Ethernet ports to 100Mb and switch off the Auto Negotiate
    1. Use a 48 VOLT power supply..!!! (either into the power jack or the PoE)
This should fix it.
Other than that we have a bunch of them on our network and they have some serious horsepower.
Hope this helps.
Tanker
Ok my friend .. Will change adapter .. And I change cable .. And i change POE. And will give you the results
thanxs
