I have a rb133/c with a senao card it has version 3.0rc4 installed and I am using
webbox.
I am trying to set it up as a client but so for i can not find any info on how to do this. does anyone have a link?
I have got it scanning for the ap’s and it finds the one i want but i can not access it
I have the ips and wep keys (hopefully in the right place)
I am now trying the psuedo station mode
any help would be appreciated
thanks dave
try this link
http://www.mikrotik.com/testdocs/ros/2.9/interface/wireless.php
and try using winbox
if you want tto stick with webbox, then go to interface and set up AP then, go to address and set up ip address for interface, now you should have functional AP configured by WEBBOX, also, consider using WPA encryption for that link, because, if you use R52 it has hw acceleration for that and why not use feature you have already paid for
my mistake I am using winbox not webbox (its on the other pc)
so far I have got it to ping the comunity network by using the psuedo station mode.
The network is using wep not wpa for their security at this stage
The link you gave me is for ver 2.9 and has no mention of psuedo station as far as i could see.
Thanks, Dave
