I have added default-small queue to sxt.How I connect to it?
Hi
I have Added default-small queue to my sxt.
now i can not connect to it with webfig and winbox.
how i connect to it?
(if i connect to it, i’ll remove queue)
If you can plug into the same layer two network then try the triple dots in win is and click the MAC address to make a layer two connection rather then an ip connection. I you cannot do that but you can access another mikrotik on the same network then go to ip and neighbors and right click on the unit and choose MAC telnet.
If you cannot do that but you can access another mikrotik on the same network then go to ip and neighbors and right click on the unit and choose MAC telnet.
Very thank you.
that solved with this your help. :slight_smile:
