I have enabled CAPs on 2.1GHz and can't enable it on 5GHz
Hi I’ve a AC2 router with latest 6.48.4, when I enable CAPs (as slave) I should select interface, and I can’t select both (2.1+5GHz), it is possible to solve it?
Can you provide more details ?
Sure,
I can select only one interface, I can I enable CAPs to the other one?
Click the down arrow next to that field to get another value to select wlan2.
thanks, wow I couldn’t expct even that )
Is it possible to have a one capsman on first router, then connect the 2.4GHz wifi of the second router to it but at the same time create another capsman on the second router to manage its 5GHz and another 5GHz third router?
Is it just necessary to specify the IP address of capsman then on capsman create the preovisioning and assign it the specific MAC of wifi interface? Is it all automatic?
You can specify multiple capsman servers on a cap but it will only use one at a time.
